I would like to know when Artlantis will be compatible with Mac os Big sur, for know it freeze as soon as we make a move.
Thank you.
Thank you.
We made some tests and did not have problems.
Could you please, contact Abvent support and send your configuration, crashlogs and logs to help us investigate the issue.
Best regards,
Thanks for you answer. There is no error reporter cash log , artlantis just freeze and the color wheel start to turn as soon as I want to move the camera.
I am using:
(Retina 5K, 27 pouces, 2019)
3,1 GHz Intel Core i5 6 cœurs
8 Go 2667 MHz DDR4
Radeon Pro 575X 4 Go
Artlantis 2020
sketchup 2018 model.
Thank you
I found a way to do it. When I open a sketch modèle before moving the camera or do any change:
1 save it as artlantis file,
2 close it
3 open the new artlantis file
4 done, I can work on it…
Hope It can help some of you with the same issue.
Have a nice day.
Thanks for your tests.
In the meantime I installed Big Sur on an external DD and also had a freeze when moving the camera, it seemed to freeze when using auto-switch (ie: switching from openGL to preview mode).
I have turned off auto-switch and now it does not freeze. I displayed the preview in openGL and then turn on auto-switch and it does not freeze anymore.
I suppose it is a problem of openGL initialization on Big Sur, we will try to fix it…
Best regards,
Hello
Is Artlantis 2020 for Mac Big Sur has any expected time?
Thanks a lot.
I ve installed Big sur and it works perfectly…except for the freezing things but it easy to fix following the steps I mentioned up here…
We should have an update for Big Sur and SketchUp 2021 import plugin next week.
Best regards,
