Comic91
Is it possible to load a personal video in a tv lcd object?
Tue 8 Jan 2019 14:58
Hi,
is it possible to load a personal video in a tv lcd objects? If the answer is YES, please tell me how I do it?
kooljay
Re: Is it possible to load a personal video in a tv lcd object?
Fri 11 Jan 2019 15:14
yes possible, copy your video file into Tm user library folder, from attaced material image locate it and picked it.
Peerman
Mon 14 Jan 2019 08:21
kooljay wrote:yes possible, copy your video file into Tm user library folder, from attaced material image locate it and picked it.
Can you show how you did this because I believe this is not possible in Twinmotion 2019. I tried it but it doesn't recognize any video format...
Best,
Peter
iMac late 2017, 4.2 GHz, 32GB RAM, Radeon Vega 64, MacOS Mojave, TwinMotion 2019, Sketchup Pro 2018, Archicad 22
adebayo
Thu 17 Jan 2019 07:33
ok.....
1.pick a video format you prefer i.e *.mp4
2.drop it in your Document > user library..
3. Now in your Twinmotion 2k19v2...
4.From your material color...
5.Click more...Texture, open, navigate to Document > user library
6.In the UserLibrary, Type your *.mp4 in the File name, automatically your file will comes up,just click open
7.Drop it on your mesh, you will see it Displaying
i hope this help...feed back please
Peerman
Thu 17 Jan 2019 08:39
Hi,
Thanks but I think this is Windows only then. I can't even select the texture (or type it in). The mp4 is greyed out.
Screenshot 2019-01-17 at 09.37.42.jpg (98.48 KiB) Viewed 647 times
So developers, if it is possible allow this for Mac users as well!!
Best,
Peter
adebayo
Thu 17 Jan 2019 10:12
its possible in windows...
Taros Nova
Mon 21 Jan 2019 08:24
Hi, I am not aware about solution given here, not working for me also.
But it is possible by adding video texture in the modeling software (3D max, Cinema, Blender etc.) before export to TM. If Your modeling software can do video texture, then just add video texture there - - - > export with textures embeded to .fbx file and it will play automatically after import to TM.
Only downside is that video is playing faster in TM - so you should slow it down to something between 10 to 20% of original speed before texture/export procedure.
A have made a short clip about it, that it is possible...see here:
https://www.youtube.com/watch?v=PKxvrwA1VKM
Hope it hepls
Martin
Tianxiao
Fri 25 Jan 2019 14:11
Dear all,
Due to a technical limit, Twinmotion 2019 doesn't support video textures.
Adding video texture directly in the modeling software, as Martin showed above, or simply add a video as a texture to a surface, is indeed a trick. However, in the export, the video will be accelerated.
Tianxiao
Tianxiao WANG // Community Manager at Abvent
Artlantis |Twinmotion | Facebook | Twitter | Tutorial
Return to “I need help”
