kteltenkoetter
videos as material textures
Wed 3 Apr 2019 09:43
Can I use videos as material textures in Twinmotion? I tried to load a movie in custom material/texture as JPG-Sequence but it doesn´t work.
jpmartin964
Re: videos as material textures
Thu 9 May 2019 15:21
Hi,
You can do it so long as you use the PC version. Technically its not supported but if you type the name of the movie in the open file bar, ie "test.mp4" for example, it will find it and you can select it.
Then just repeat the process for the glow channel, add a bit a reflection and bingo, you've got a video clip playing on a surface.
Return to “I need help”
