digipi wrote:Good day!
There is a wish for the new functions of the Artlantis program: when saving a 3D object as an Artlantis object, do not save the HDRI map along with the 3D object used to preview the 3D object.
Those. so that only on the preview of the 3D object this map is applied, but does not increase the weight of the 3D model itself when saving.
Otherwise, HDRI-maps usually weigh a lot (several hundred MB).
Please make such a function so that we can turn off the HDRI-map and not include it in the model when saving a 3D object.
Then the 3D models will have beautiful previews and will not weigh several hundred MB.
You can save as Object with a pre-rendered preview.
For this, you need to render the object with the HDRI and save the render under the name preview_XXXXX.jpg, where XXXXX is the Object file name, in the folder where you will save the object.
Then remove the HDRI and save the object.
For example, if you want to create an object named MyObject in folder MyMediaLibrary, then render a preview named preview_MyObject.jpg in the folder MyMediaLibrary, then save as object with the name MyObject in the folder MyMediaLibrary, you will get 2 files MyObject.atlo and MyObject.jpg
Hope I'm clear.
