Nenius
Contact: Website
Vista 2d does not look right.
Tue 14 Mar 2017 15:37
Hello :
In version 6.5, I can not find the way to correctly see the 2d view, in order to place the objects in the desired location. In the screen shot, note that the walls are not visible. Note that the right arrow in the Botton is clicked, if it is not everything disappears. Is there some way to fix it?. In previous versions you could see without any problems.
Captura de pantalla 2017-03-14 a las 12.36.21.png (1.47 MiB) Viewed 1952 times
Captura de pantalla 2017-03-14 a las 12.26.46.png (1.59 MiB) Viewed 1952 times
Thanks in advance!!
kgriffith
Re: Vista 2d does not look right.
Tue 14 Mar 2017 17:28
Try going to the Preferences dialog, and changing your Open GL display option. I think you'd want "wireframe", or "Color and Wireframe". Not sure but this might do it...
Nenius
Contact: Website
Tue 14 Mar 2017 18:26
YES!!!
you are right!!, thanks a lot!!
Thanks in advance!!
Return to “Artlantis General”
