digipi
A new version of Artlantis 2020 has been released.
Sun 17 Nov 2019 07:31
Thanks for the new version. :)
Shaders and textures (images jpg, png, tif …) cannot be applied to the Infinite Ground (in Windows 8.1 Rus):
https://youtu.be/0TXFxWnfDTk
For some reason, 3 Shaders with grass (seen in the video) and 3 Shaders with water are transferred to the material of Infinite ground - AV_Natural_lawn_001, AV_Natural_lawn_002, AV_Natural_lawn_003, AV_Natural_Water_001, AV_Natural_Water_002, AV_Natural_Water_003.
In the material parameters, the bevel setting disappeared, only smoothing remained.
The material parameters tab is also minimized when you open the project, although it would be more convenient and logical if this tab always showed, otherwise it is difficult to find for beginners.
P.S. It is a pity that many wishes of the users are not taken into account - https://forums.abvent.com/viewtopic.php?f=69&t=4348 ...
vellmans
Re: A new version of Artlantis 2020 has been released.
Sat 23 Nov 2019 08:03
It’s less than 16 months I bought version 7. Now it’s already mentioned as ”older versions” in price list of local dealer. Fastest timetable without normal updates I’ve seen in any program.
rad2
Wed 4 Mar 2020 09:36
Hello !
Which ARCHICAD versions are supported by Artlantis 2020 ?
ARCHICAD 13 is intresting for me.
Wed 11 Mar 2020 14:31
Version 13 is supported in the way that Artlantis can open files generated by ArchiCAD 13 atl exporter.
Werner_Dielen
Fri 13 Mar 2020 15:57
You can allways use 3ds export from archicad and import this file in artlantis.
digipi
Tue 7 Apr 2020 05:40
Good afternoon!
Please add a quick mirror function for 3D objects horizontally and vertically (check the box in the object parameters window). Now it’s very inconvenient to unfasten the lock at the sizes and put a minus on one of the sizes, and many users do not know this method ...
And the rotation function of scene objects with changing rotation angles (X, Y, Z) does not work correctly now - the values of the entered angles are not fixed and the object behaves strangely after several changes in the rotation angles - it turns one way, then the other ...
Thanks!
Tue 7 Apr 2020 08:46
Thanks for your input.
We will look into it.
Best regards,
Return to “Artlantis General”
