Nenius
Contact: Website
Grainy
Mon 27 Mar 2017 20:07
Hello:
I know that sometime, this was discussed, but I can´t find it now. Can anyone help with this image? It´s too grainy. I share my settings.
Please I need an advice.
Thanks
imagen granulada
Rincon con mas LUZ.jpg (196.15 KiB) Viewed 3500 times
settings
Captura de pantalla 2017-03-27 a las 16.57.25.png (4.57 MiB) Viewed 3502 times
Thanks in advance!!
kgriffith
Re: Grainy
Tue 28 Mar 2017 16:42
I am not sure, but my guess would be that you need to increase your material sampling and or your light sampling.
Also, it appears you have "Enhanced Background" checked. Are you using an HDRI? If not, I don't think you need that checked. Turning off Enhanced Background might make a difference as well.
Nenius
Contact: Website
Re: Grainy
Tue 28 Mar 2017 17:57
Thanks a lot!
You are wright. Compare the difference, much more better.
Light sampling and material sampling are put to the highest, and not checked "Enhanced Background".
Best regards
2-RinconLUZMasMuestreoSin FonfoMejorado.jpg (372.59 KiB) Viewed 3478 times
Thanks in advance!!
juancamiloarq
Re: Grainy
Wed 29 Mar 2017 14:51
The main reason you were having that grainy rendering is because of the "Enhanced background" option. You should never use it in interior renderings.
Juan
Nenius
Contact: Website
Re: Grainy
Wed 29 Mar 2017 17:38
OKI,
Thanks
Thanks in advance!!
Return to “WIP”
