kgriffith
ArchiCAD 21 Plug-in
Mon 30 Apr 2018 16:21
Any information on when this will be available? As all my current projects are in AC21, I can't use Artlantis 7 until the plug-in is available. Thanks.
kgriffith
Re: ArchiCAD 21 Plug-in
Wed 2 May 2018 12:48
OK, thinking that maybe I will just save my project back to ArchiCAD 20 and then export to Artlantis & from there, I download the plug-in labeled "ArchiCAD 20 to Artlantis 7". But when the file downloads, the file name is "ARCHICAD_20_to_ATL6.5-Win".
I can already export from ArchiCAD 21 to 6.5. If I do that, then open in Artlantis 7, would that create any problems?
Wed 2 May 2018 14:13
The file format did not change between 6.5 and 7.
Hence, you can use de ArchiCAD exporter to 6.5 and open the exported file in Artlantis 7.
There should be no problem.
ArchiCAD 21 export plugin is installed with ArchiCAD 21, you can use it to export to Artlantis 7.
Sorry for the delay...
kgriffith
Wed 2 May 2018 16:04
Thank you.
Return to “Import & Plugins”
