EGMarchitecten
Central texture library
Thu 2 Feb 2017 10:32
When starting Artlantis I get an error for missing textures. These textures a'ren't moved of anything. This happens when a collegue opens the file on another system with the same acces to our central media folder.
Is there a way to manage textures and objects in a central location so we don't get the missing object error when we open the project. Yes we can select all the files and point to the folder, but this is a hassle is we have to do this everytime.
Thanks in advance and hopefully you guys know a solution.
Greetings, Patrick
Re: Central texture library
Fri 22 Sep 2017 15:47
I need to clarify something:
Are you both opening an atl file that is in the central texture library or is it only the textures that are on the central library and you both have your atl file on your machine ?
