RobertJRB
Shaders from objects linked in ATL6.5
Sun 12 Mar 2017 21:14
Lets say I place two chairs in my model. In ATL 5 I could change their shaders individually so I was able to change the color of only one.
Now I just updated to ATL6.5 and I notice shaders from the same model are linked to eachother. So if I change one chair the other goes along.
Can this be turned off?
Ildiko
Re: Shaders from objects linked in ATL6.5
Mon 13 Mar 2017 10:30
Hi, since version 6, you change materials for all instances at once. To detach one instance from the group, open the Object inspector and make a right click over the instance which should have a different shader. Choose: Use Independent Material.
The same contextual manu contains further options for object materials.
kgriffith
Tue 14 Mar 2017 17:33
If you go to the tutorials on the Artlantis website, you will find tutorial "10 - Instances" covers this functionality.
RobertJRB
Wed 15 Mar 2017 09:23
Thank you both! Will give the tutorials an try.
