sandropc
ATL Bilboards
Wed 5 Jul 2017 02:54
Hi:
It is possible to use the old Bilboards in Artlantis 6.5? I haven´t they appear cutted. Someone can solve this problem?
Thanks in advance
Re: ATL Bilboards
Fri 22 Sep 2017 15:27
Yes you can use Billboard in Artlantis V6.5
Which Billboard are you using ?
Could you attach one of the BB you are having problem with.
Please attach the atlo and jpg file
sandropc
Re: ATL Bilboards
Mon 13 Nov 2017 18:17
Thanks Camille, sorry for the delay...Attached the ATL file, a render and the BB folder.
Thanks again
Sandro P
BB Cutted.jpg (515.68 KiB) Viewed 2996 times
sandropc
Re: ATL Bilboards
Mon 13 Nov 2017 20:28
As you can see, the 3D model (woman) and the white BB that come with the program are good, but the BB people appears cutted! that do not happen with previous releases....
Re: ATL Bilboards
Tue 6 Feb 2018 16:27
I have seen this problem before, the geometry in the BB file is wrong, the 2 triangles used to define the rectangle on which the texture is applied are defined at the same position.
In this picture I have drawn the 2 triangles (1 red, 1 yellow) at the position they should be, in the BB file, they are both defined at the position and orientation of the yellow triangle, hence the texture problem...
I don't understand why they worked with previous version though...
Where did you get them from ?
It is possible to fix this issue using "Artlantis Implode Explode" application and a text editor.
If you want to do it, I can explain the steps to follow.
Let me know.
