Thiago
Neon Light Shader V6.5
Tue 5 Sep 2017 03:05
Neon light shader .... why are you so absurdly grainy?
Scene 12.jpg (101.73 KiB) Viewed 3393 times
Thiago
Re: Neon Light Shader V6.5
Mon 11 Sep 2017 19:36
Abvent????????
Fri 22 Sep 2017 09:55
Hello Thiago,
Sorry for the delay.
What lighting, appart from the neon, are you using ?
HDRI, Sun ?
Which rendering parameters did you use for this image ?
Could you attach the atla of the file you used to render this image.
Fri 22 Sep 2017 10:18
In you render, I think most of the grain can be removed by increasing the global illumination interpolation value to 5.
I tried to build a scene looking like yours.
I have a night heliodon, one suspended lamp and a lamp object with one face set with neon shader.
I used the "Low light" "medium" pre-defined rendering setting with AA 3x3 to get this image:
Fri 22 Sep 2017 10:27
In your image, it seems your camera is outside in day time.
did you check the "enhanced background" ?
what is the lumen value of your neon shader ?
Thiago
Tue 17 Oct 2017 19:40
The problem continues...
Neon 2.jpg (230.36 KiB) Viewed 3227 times
Wed 18 Oct 2017 08:49
Could you attach a zipped atla, I will try to check what is wrong.
thanks.
Wed 18 Oct 2017 09:48
Thiago wrote:The problem continues...
I think you need to increase the interpolation to 5 and you do not need the AA set to 4x4, 3x3 is enough.
In fact, you should try using the "Low light"+"medium"or "high" parameter pre-set, it should look better !
Best regards,
