ProjectWelt
My shader won't apply?
Thu 28 Dec 2017 14:12
Hello everybody,
I've drawn a bathroom in Sketchup pro 2018 that I'd like to render via Artlantis. Normally I would use a sketchup I've attached in SketchUp en render it like this, I never had any trouble with it. Now I have a texture in the shower that works on only two walls. I tried to copy the texture to the walls that are just white (but has the same texture). In my shaders menu on the left I can see that the wall contains the shader, but nothing happens?!
Can you guys help me out? :(
Thanks!
kgriffith
Re: My shader won't apply?
Thu 28 Dec 2017 17:12
I don't work with SketchUp, so I'm not sure if this will apply, but when bringing in a model from ArchiCAD, I have noticed that if a surface has a shader that was imported from ArchiCAD, an Artlantis shader won't show unless I first delete the ArchiCAD shader. Both shaders show on the menu to the left, but only the ArchiCAD shader shows in the 3d view. Hope that helps.
Tue 6 Feb 2018 16:05
Did kgriffith answer helped resolving your problem or do you still have the same issue ?
