csaba
Cylindrical or spheric objects
Mon 12 Mar 2018 14:12
Hei! Help please! Every cylindrical or spheric object in my Artlantis 6 project is faceted and has treangled holes in it, even if I set smoothness to maximum. I tried in Artlantis 4 also, but it happens the same thing. Do you have an idea what does it happen? Thank you!
pr 20.jpg (423.97 KiB) Viewed 5804 times
pr 17.jpg (125.2 KiB) Viewed 5804 times
pr 13.jpg (118.09 KiB) Viewed 5804 times
Re: Cylindrical or spheric objects
Wed 14 Mar 2018 08:53
Where are the objects chairs coming from ?
Could you attach one of them to this post (jpg + atlo) or attach the zipped atla of your file.
Best regards,
csaba
Wed 21 Mar 2018 20:26
Hi! Thank you for your answer and sorry for my late answer! I use ArchiCAD 21 for modelling and this chair was downloaded as gsm modell. I attach it here. But as I mentioned, all of the curved surfaces will be faceted in the rendering, not only this chair, you can see them in the jpg`s attached in my previous comment. In Artlantis 4 this problem isn`t happen. Can`t attach that format by the way.
Regards,
Csaba
Thu 22 Mar 2018 11:48
This is strange.
Could you send me the chair via mail or WeTransfer at sarrut@abvent.fr
If I understand it is a gsm, you instantiated in ArchiCAD and exported in atl ?
can you send me the gsm or the ArchiCAD file.
Thanks,
csaba
Thu 22 Mar 2018 21:09
Ok, I send it to you in mail, but as I mentioned not only this object is faulty but every curved surface. See the wooden chair as well with cilindrical legs. In fact it is something wrong with some flat surfaces as well...if you check the image posted by me, there is a laptop on the desk which has strange triangles on its surface some should be completly flat.
Regards,
Csaba
csaba
Thu 22 Mar 2018 21:15
One more thing...if I render it as ArchiCAD 18 and Artlantis 4 they will be completely perfect.
