gonen
can get the VR object to work
Thu 26 Oct 2017 09:21
hi all,
I need help
I did a VR project and when I run the HTML I get a blank screen.
the flash player is installed and I try to run chrome and explorer and Mozilla all the same.
very urgent helpppp
I have ver 6.5
if I try on 4.5 it is ok as a *.mov file
gonen
israel
Re: can get the VR object to work
Thu 26 Oct 2017 13:58
You need to change the Flash preferences.
Please follow those steps:
- right click in the dark-grey square:
- choose "Global settings..." menu item
- choose the "Advanced" tab:
- click the "Trusted locations settings..." button
- add the folder containing your VRObject folder to the list:
- close the list
- close the "Flash" preferences window
- reload the page
You should be able to visualize your VRObject !
You need to do the same for Panorama
You can add a folder in which you will save all your panoramas and VRObject, this way you won't need to change the settings every time.
I have done the screenshots in Safari on Mac OS X 10.10
Cheers !
ngh
Thu 6 Dec 2018 00:19
I am having the same results. However the proposed fix isn't working for me. When I choose "Global settings" I do not get a screen with an "Advanced" option. Other suggestions?
Fri 7 Dec 2018 10:39
ngh wrote:I am having the same results. However the proposed fix isn't working for me. When I choose "Global settings" I do not get a screen with an "Advanced" option. Other suggestions?
This is strange, did you install the latest FlashPlayer ?
Return to “Animation”
