jrutherford
Transparent Background
Wed 26 Apr 2017 18:19
Is there a way to directly export a PNG with a transparent background? I can post process in a photo editor to achieve this but it is not an optimal solution.
regi
Re: Transparent Background
Thu 27 Apr 2017 20:10
Hi - Hopefully I'll get you right
If you export to psd, you will get a picture which is divided into different layers.
Your model will be rendered there without being merged with the used background
but with transparent background instead ;) Even an ambient occlusion layer gets created!
Then you can use other backgrounds for example or skys etc...
You also get very uesful layers there like material- or object IDs for postpro...
jrutherford
Thu 27 Apr 2017 22:00
Hi
I agree that the PSD export is useful in creating a mask to isolate the rendered object. The PSD color layer contains the rendered object and the background, I was looking for just the rendered object on a transparent background layer. Any other options?
regi
Mon 29 May 2017 05:11
... And the absolute "All-Around-Happy Package" would be to get the shadow on it´s own separate layer as well !!! ;)
Return to “General”
