edv@a-a.lu
RenderIN doesn't appear in 'PLUGINS'
Thu 17 Aug 2017 06:45
Hi all,
after installing the plugin does not appear in the flyout 'plugins'.
Software in SU 2016 on mac.
any ideas. thank you
carsten
architecure + aménagement s.a.
http://www.a-a.lu
regi
Re: RenderIN doesn't appear in 'PLUGINS'
Mon 21 Aug 2017 18:02
Hi Carsten
I´m not sure if that helps because I use a Windows system and I do not know whether that is similar in the MAC version.
Did you check this hook to enable the tool?
SurroundYouDesign
Fri 19 Jan 2018 02:14
I have the same problem, did you find a solution yet?
Return to “General”
