garytcosta
How do you turn off Sketchup Sun and Shadows, Render[in]3?
Wed 31 Jan 2018 17:28
Hey folks,
Wondering if anyone knows how to turn off Sketchup's native sun & shadows in Render[in]3 so that you can light scenes with Render[in] lights only?
Render[in] 2 had a 'button' in the environment drop down window that allowed you to do that. I don't see anything similar in the Render[in]3 environment drop down.
Has that function moved to a different place in the UI, or is the process for turning off Sketchup sun & shadows different?
Any advice would be helpful.
Thanks,
Gary
SWANK-E
Re: How do you turn off Sketchup Sun and Shadows, Render[in]3?
Fri 2 Feb 2018 00:00
Just put the time to before sunrise or after sunset in SketchUp
garytcosta
Sat 3 Feb 2018 02:12
Thanks for the info.
Is setting the sun/time to after sunset or before sunrise the 'official' way to turn off Sketchup sun/shadows in Render[in]3, or is that a workaround?
Seems like a convoluted way to do that seeing as Render[in]2 had a 'switch' that did that.
garytcosta
Sat 3 Feb 2018 02:14
It would be nice if a moderator or Abvent rep would chime in on this.
Return to “General”
