regi
"Fire Flies" Render Bug
Fri 11 May 2018 06:01
I need some help or guidance please!
whenever i render an interior and use any shininess for materials (for example a wooden floor) this fire flies effect occurs. Those are the many little white dots as you can see below. And I can't find a way to avoid that. - So I am happy about every help and every hint...
for now i can only avoid any shininess at all, which drastically reduces my render quality :cry:
FireFlies Render Settings.jpg (137.54 KiB) Viewed 1849 times
ardillamex
Re: "Fire Flies" Render Bug
Mon 2 Jul 2018 16:00
Have you put some bumps effect ?? It may causes that effect.
A little question does your render stop at 3/4 100% or does it continue to the end....
Thank you.
Return to “General”
