regi
How to avoid Halo Lighting ? - Help!
Fri 12 May 2017 09:52
Hi All
Whenever I make any light fixture like seen in the sketch below, regardless of whether I use an emitter material, a point light or a spotlight as a light source, this light fixture always causes Halo Lighting on the ceiling or at the wall around the light fixture . But since the light fixture is made like seen in the sketch, this should not happen.
What am I doing wrong ?!? - please help!
halo-lighting-th test 007.jpg (117.64 KiB) Viewed 2473 times
Mélanie
Re: How to avoid Halo Lighting ? - Help!
Fri 12 May 2017 11:17
Hi,
Make sure that you checked the Shadow box in the options of the light, or that your light is not too close from the ceiling.
Maybe could you share a example file with us ?
Best regards
Mélanie Matthey // Société Abvent
Twinmotion| Newsletter | Facebook | Twitter | Tutorial
regi
Fri 12 May 2017 12:16
Thank you - I just sent you a skp file via email
Return to “Feedback”
