Vidy
My Experience on Renderin V.3
Tue 9 Feb 2016 14:12
Dear Admin,
I have a licensed Renderin from the Beta Test of V1, being a V2 i feel there is a major leap from V1, with this V3 i kind of felt opposite way, here are some of my experience:
1. Preview Box
V2 (Sharp) feel more confident from V3 (Blurry)
2. Rendering Time
V2 much faster than V3
3. Result
V2 still more convincing then V3
V2 Result
V3 Result
I am not sure is there because of i am just rendering the previous SU File (with the V2 setting), but with the V3, don't you think we supposed not need to re-tweak the scene right?
I will keep trying to experimenting on this new version, it just somehow the longer render time is kind of blown away my mood.
Regards,
VD
Vidy
Re: My Experience on Renderin V.3
Wed 10 Feb 2016 04:19
Hi,
Ok, been played with V3 again, i found that adjusting Rendering Image is hard to do, it seems to be so heavy until it just grayed out, check attached image below:
so, i will render just with the given image proportion
Regards,
VD
mercheric
Thu 18 Feb 2016 11:20
You're right, the engine is totally new, so the settings need to be reviewed.
Concerning the rendering window size, we check
Vidy
Re: My Experience on Renderin V.3 (Emitter Material Problem)
Sun 21 Feb 2016 05:22
Hi Eric,
Thank you for your confirmation, will re-setup again for this new engine.
I found a little glitch when trying to setup a Light Emitter Material (Neon Shader), so i create an object as represent of the stripe light, i made the neon shader (light emitter material) and apply it to the object, and then i copied it to get it to other place, when i render it's only 1 that has a good effect, the other kind of lit but not have a glow.. Check below for some shot:
Image 01:
Image 02:
Regards,
VD
Return to “Feedback”
