Polygon
Kitchen render[in] v3.0.6
Thu 7 Jul 2016 12:48
Hii All,
i wanted to share my latest work with skp&render[in].
feel free to give feedback.
thx :D
regi
Re: Kitchen render[in] v3.0.6
Fri 8 Jul 2016 05:39
WOW !!! For me this is definitely a render for the Render[IN] Gallery !
Everything: the lighting, the materials, the scenes setup with the right amount of deco details, the camera view....
If you would have increased the degree of detailing at the window a little, so you could see the glass pane frame within the window frame, I wouldn´t be sure if I see a photo here :D
The lighting - Is it only daylight shining through the window on the left?
Polygon
Fri 8 Jul 2016 09:29
Hay Regi,
Thx for the nice feedback, i'll give more detail to the window asap, indeed it would be much more realistic then now. :D tx.
lightning is daylight + lightplane(emitter) infront of the windows (kitchen nd living room) + in the end a little bit PS curves correction.
i did the same test with vray, as much as possible i can with the time i had.. in the end i like the render[in] render more...i think.. both softwares as its positive things i see :).
After im done with the work i can ask the client if it can be showed @ the standard gallery of render[in]
adittional info abt the render:
1920x1080
high quality(standard templ)
ambocc 10/10
iso 25 - shutter 60
asus g74sx
16gbddr3 - i7 2630qm
gtx560 3gb
render time:74mints
regi
Sun 10 Jul 2016 10:23
Hi Polygon
First, thank you for your detailed information above!
I apologize that I am so bold (?) to imitate your great scene. But, as I have already noted, your lighting result is so good that I want to learn to improve my own lighting skills as well. And just to get a comparable scenario, I decided to use your scene, which I imitated with SU PhotoMatch, filled with some scenes components from the 3D Warehouse. So sorry once again!!
For my test, I used generally the settings, which you've described above.
Interesting is the difference between the scene which uses daylight only and the scene which uses an additional light-emitter, as you have recommended.
Overall, I reached a satisfactory result but it is still far behind your lighting quality - would you please do me the favor to describe your method a bit more precisely, maybe with a scene-screenshot, how you used the emitter planes? - Of course only if you want or can...
Thanks & Regards, Regi
PS: also I used Vray already (in addition to some other renderers) - with this tool, just like with some other tools - the effort to reach any good result in a reasonable time was too big for me. To use Render[IN] was the result of a long search and comparison. With Render[IN], particularly for interiors, the effort to get a good result is the smallest and the fastest for me so far...
regi fake.jpg (284.75 KiB) Viewed 3833 times
regi
Sun 10 Jul 2016 10:47
One more question :?
Does it make any difference to regulate lighting with ISO or Shutter ?? I have no idea
Polygon
Sun 10 Jul 2016 20:05
Hi Regi,
No its cool. No probl at all. At this moment im with vacation nd didnt brought my notebook with me. Whn im back i promise to look at ur model(maybe u cn send it by wetransfer) so i can see the settings on the model nd send it back to u so u cn see the difference between ur model nd mine.
Question about the iso md shuttersp. I think both use light in a different way, when i used artlantis i always tryd to keep the balance between those 2.. Its more the feeling i get when i see the result in the preview instead of using standard settings.
At the living room i have also 3 large windows from 0till 3mx1m.
I contact i asap.
Take care byy
regi
Mon 11 Jul 2016 05:29
8-) no need to hurry at all - thanks and enjoy your vacation 8-)
Return to “Work in Progress”
