Debucquoy
Home office
Wed 21 Dec 2016 21:07
Here's a render I'm working on, please give me your comments, advice, suggestions...
Imagehebergeur d image
regi
Re: Home office
Wed 28 Dec 2016 08:55
Hi and sorry for this late answer
This is a most beautiful room, which is obviously modeled very acurately as well!
The lighting and the material suggestions appear more like native SketchUp look to me somehow but
less like a rendered image. Everything is a bit too clean and too perfect for me - why gets nothing reflected in the glass pane for example?
Or, For example, the wood floor could have some shinyness or at least glossiness - the same might fit to the wood surface of the cabinets maybe?
I would separate the floor meterials from the office against a new and own balcony floor meterial (of course just if this is a balcony?) with another flooring material and a "complete" window frame at the ground line.
Also to reduce the strength of sunlight but adding any additional artificial lightinging could be most useful here.
A last suggestion: add any but not too much detailing that brings "life" to the scene - so you can lean a bag at the desk or cover a coat over the chair, as if you've just come into your office, hastily stuffed your things somewhere to activate a coffee machine first before you start to work... :-)
These are only suggestions because you have asked for it :P
Return to “Work in Progress”
