Nenius
Contact: Website
Noisy background
Wed 2 Aug 2017 17:32
Hello you all
I´m having problems with the grass shader. I share my setting and the example. I don´t know how to fix it. Anyone can help please?
I don´t like the grass, is too noisy. I tested with many different grasses, always the same.
Thanks!!!
settings
Captura de pantalla 2017-08-02 a la(s) 14.29.10.png (1.29 MiB) Viewed 5960 times
render
Thanks in advance!!
Re: Noisy background
Fri 22 Sep 2017 11:00
Did you try increasing the size of the grass shader ?
Nenius
Contact: Website
Fri 22 Sep 2017 13:33
Hello Camille
I´ve also tried increseasing 2 and 4 times the size. But I don´t see a substantial difference.
What do you think?
4 times the size
4 times the size
Pasto 10.jpg (160.88 KiB) Viewed 5846 times
2 times the size
Pasto 5afuera.jpg (75.03 KiB) Viewed 5846 times
2 times the size
pasto 5.jpg (57.84 KiB) Viewed 5846 times
Thanks in advance!!
Fri 22 Sep 2017 17:27
Hello again,
Are you using HDRI lighting ?
Because that might cause the problem.
If you use HDRI, you need to use Exposure 1, check Enhanced background, set light sampling to 5 and check Automatic white balance.
Hopefully this should help removing the noisy effect on the grass shader 8-)
This is what I've done for this image:
Settings:
Nenius
Contact: Website
Sun 24 Sep 2017 23:16
Hello Camille
It´s not better. I tried the same settings as you recommended me, and similar setting without HDR.
as you recommended
Captura de pantalla 2017-09-24 a la(s) 20.13.12.png (1.24 MiB) Viewed 5834 times
similar, but no exposition
Captura de pantalla 2017-09-24 a la(s) 20.12.52.png (1.37 MiB) Viewed 5834 times
Oeste con HDR.jpg (221.81 KiB) Viewed 5834 times
Thanks in advance!!
Nenius
Contact: Website
Sun 24 Sep 2017 23:17
this image was missing, is the one your recommended me
Oeste con HDR segunCamille.jpg (464.44 KiB) Viewed 5831 times
Thanks in advance!!
Tue 26 Sep 2017 09:00
With the recommended setting the grass is a little less noisy. I'm not sure we can make it better... sorry
I can ask Stephane Desmulie when he comes back from vacation next week.
But the image is too bright, maybe change the lighting power of your HDR.
Best regards,
Nenius
Contact: Website
Tue 26 Sep 2017 11:39
Ok, perhaps she has any idea. Please, let me know. Thanks and
Regards
Thanks in advance!!
Tue 10 Oct 2017 08:55
Stephane told be the noise might come from the bump value of the grass shader. Have you added some bump on the grass shader ?
Best regards,
Nenius
Contact: Website
Thu 12 Oct 2017 14:04
Hello.
There´s no bump added. But It seems the images looks better, what do you think? I attach them with the Camille advice settings, and another with similar settings
Settings 3.jpg (760.23 KiB) Viewed 5720 times
Settings 3 s_Camille.jpg (190.73 KiB) Viewed 5720 times
Settings 2.jpg (836.45 KiB) Viewed 5720 times
Settings 2 s_CamilleExposure1.jpg (205.68 KiB) Viewed 5720 times
Settings 1.jpg (600.03 KiB) Viewed 5720 times
Setting 1_Suite.jpg (148.21 KiB) Viewed 5720 times
Thanks in advance!!
