Arch3D
Atl6.5: No smoothing for specular highlights from Sun and Lights.
Tue 12 Sep 2017 15:55
This Bug is still not solved in V7.0...
In Artlantis 6.5 the specular reflections from sun and/or lightsources are not smooth even if surface smoothing is set to max.
Look at the examples:
surface smoothing off (hard)
surface smoothing on (soft)
Re: Atl6.5: No smoothing for specular highlights from Sun and Lights.
Thu 21 Sep 2017 17:15
Strange, I cannot reproduce...
Could you please, attach your test file (as zipped archive ATLA).
Thanks,
Arch3D
Tue 26 Sep 2017 10:15
Hello Camille
Here is a very simple Testfile with a sphere and a torus. Sunlight and one red Light.
The highlights are not smoothed correctly, if the surfaces are smoothed.
The atla (6.5/ 6.5.2.12) file is attached.
Thank you for testing and hopefully resolving this problem.
Test Atl65.atl.zip
(5.64 KiB) Downloaded 33 times
ACCamera_edges hard.jpg (36.72 KiB) Viewed 1278 times
ACCamera_edges soft.jpg (35.44 KiB) Viewed 1278 times
Arch3D
Tue 26 Sep 2017 10:24
The lower the glossyness of the material, the better the effect is visible.
Another example with glossiness set to minimum:
ACCamera_edges soft2.jpg (35.65 KiB) Viewed 1278 times
Tue 26 Sep 2017 10:40
Arch3D wrote:Hello Camille
Test Atl65.atl.zip
I have downloaded the file, but it is missing the tif, sphere, taurus and the red light... Could you attach an atla, this way I would have exactly the same file as you have.
Thanks,
Tue 26 Sep 2017 10:52
I have reproduced the problem, don't bother sending a new file !
I will enter a bug and let you know if it can be fixed.
Thanks,
Arch3D
Mon 28 May 2018 15:34
Ok, thank you for the quick response.
RobertJRB
Wed 13 Jun 2018 09:27
I have the same issue with many of my models. Would like to see that its possible to fix.
Wed 13 Jun 2018 12:33
Hopefully, we will try to find a solution for the next release.
Return to “Artlantis General”
