haydencampos
Problem When Rendering Using an NVIDIA GeForce 940M Video Card
Wed 21 Mar 2018 19:50
Hi, I'm having a problem, when rendering my model, if I set the computer to use the NVIDIA GeForce 940M Video Card as standard, the result is a bug on the screen, where it shows the rendering process, it is not see the stages and also the render time.
depending on how I set up the video card, the software, at the time of rendering, automatically locks and closes.
I would be grateful if anyone could help me with this case.
Re: Problem When Rendering Using an NVIDIA GeForce 940M Video Card
Thu 22 Mar 2018 11:45
This is a known issue we have with Windows 10 and Nvidia graphic cards on laptops, since Windows 10 december update. (viewtopic.php?f=69&t=2153&p=7902&hilit=nvidia#p7256)
Unfortunately we have not found how to fix it yet, but we are working on it.
As a work around, you can try to downgrade your graphic card driver.
You can find old drivers there: http://www.nvidia.fr/Download/Find.aspx?lang=en
You can also force Artlantis to use the internal graphic card instead of the Nvidia, it might get a little slow but it will work.
haydencampos
Fri 23 Mar 2018 12:15
many thanks Camille, I will try the downgrade option, today I am using the graphics card of the
notebook itself but the rendering is extremely slow.
Best regards.
CamilleSarrut wrote:Hello,
Fri 23 Mar 2018 14:06
I do not think the rendering is slow because you are using the internal graphic card, because the final render uses only the CPU.
I would think it is more related to the rendering settings or the light or shader settings.
I think the bug with Nvidia is only a display on screen problem, at least for the final rendering window, the output image is correct, so you could try rendering with Artlantis and Nvidia graphic card active to see if the rendering is faster.
haydencampos
Mon 26 Mar 2018 14:20
The driver downgrade did not work out, the problem persists, even downloading for a June 2017 version, I will check if the rendering time is less using the nvidia card even with this screen problem. Thank you very much, have a great week!
SvenQuasters
Mon 26 Mar 2018 16:38
I have the exact same graphics card.
The latest working driver on my laptops is 382.05.
Hope this helps you?
haydencampos
Thu 29 Mar 2018 18:24
Thanks SvenQuasters for the tip, I'm testing several possibilities, I'm going to test this drive
version that you indicated... have a great week!
SvenQuasters wrote:Hello,
SvenQuasters
Wed 8 Aug 2018 10:28
Can someone who upgraded to ATL 7 confirm this issue is resolved?
Wed 8 Aug 2018 13:39
Unfortunately no... We have had no help from Nvidia nor from Microsoft to solve this issue and we did not find another workaround...
Hopefully an update from either Windows10 or Nvidia might help...
Wannabedesigner
Tue 21 Aug 2018 19:10
This is disappointing, and something that will no doubt effect many people given the number of people who use these GPUs.
I'm a bit confused thought, and hoping this can this be looked into further as the 'fix' for Artlantis 7 is to roll back to an NVidia driver from September 2017 (or before), however my understanding is that 6.5 works quiet happily with more recent NVidia drivers. To me this suggests the issue has been introduced with 7, and can be addressed on the Abvent side??
PS the fix isn't simply a case of rolling back the driver, you'll find the issue returns the following day, and as a result you'll have to update the driver to current, then roll back again.. and repeat.. every day you need to render. Not ideal for a market leading product.
Return to “Artlantis General”
