juancamiloarq
Artlantis 7 has been announced
Fri 20 Apr 2018 23:59
Is it really faster than the previous version? As I see nothing new and Abvent is charging 160 EU for 6.x users.
Is it worth it? :|
Juan
Portymixer
Re: Artlantis 7 has been announced
Sun 22 Apr 2018 01:30
I've done a few tests and it seems to be a lot faster, like nearly 200% with image quality the same. On a down side when I increased the render from 'quality' to maxing out the sliders the images seemed identical. I'll try some larger projects and see what happens.
Michael lennie
Arch3D
Thu 26 Apr 2018 12:14
In a first quick test i noticed that if antialiasing is set to 4x rendering time is faster, but i think with a little less quality.
Also the borders of the shadows look grainy in V7 compared to V6.5 with same settings. Look at the examples (image detail zoomed to 300% to see the difference).
If antialiasing is set to off, rendertime is about the same.
And i don't see any difference from the artificial lights in this scene if i switch between the 2 renders.
Image detail V6.5:
V7:
digipi
Thu 10 May 2018 16:27
CamilleSarrut wrote: digipi wrote:
And why now I can not see the names of the postcards (earlier in Artlantis 4 were the names of each postcard)?
Without the name of postcards for example it is not clear what material on the card is located.
This is a bug, the names are displayed in the list on the Mac version, but not on the Windows version. We will fix this
Link - viewtopic.php?p=8433#p8433
Corrected or not in Artlantis 7 not displayed names of postcards on Windows OS?
kgriffith
Fri 11 May 2018 10:57
I am using 7 - can't see the names of the postcards
Tue 15 May 2018 08:37
It is not fixed in version 7, It will be fixed in the next release !
tmigrin
Wed 23 May 2018 15:11
I have noticed very little difference between version 6.5 and version 7. Version 7 does seem slightly faster, but the quality was better in version 6.5. I have always had a problem with graininess in my renderings and that seems quite a bit worse in version 7. On the plus side, I have had several issues with billboards in versions 6 and 6.5 and that seems to have been fixed in version 7. Finally, part of the reason we upgraded to version 7 was the advertised option to use Twinlinker. This sounds like it could be useful but there is NO help or instructions for how to use it. I have tried multiple things to bring in a file from Artlantis, but nothing seems to work. Any suggestions would be much appreciated.
Return to “Artlantis General”
