Taros Nova
Relocating import file
Wed 16 May 2018 11:55
Hi, I found a bug on importing file, when i try to relocate - or load updated/renamed file.
This is the case when I use "other" filetypes for import....then, when You want to relocate - in filetypes option, there is only fbx, skp, obj, c4d and no more option to load one of "other filetype". Therefore, I cannot change the name or path to file when i use import from .lxo in my case.
Not a big deal at first and when You work on 1PC. But when I want to work on same file on another PC (at home / at work) - I cannot relocate it, so I had to start from scratch or finish project on the PC where I started. This case it is a big deal... Please correct this annoying bug.
(see screens below)
Thank You, Martin
importing first time - other filetypes available
relocating
other filetypes not listed - therefore my file cannot be selected
Return to “Feedback”
