xiveros
2019 brakes texture
Wed 27 Jun 2018 08:06
file saved in 2018, opened in 2019
most textures have artefakts like that.
Also terrain's texture seams to be "moved" or "stretched"
In general 2019 is not a new version, but just update of 2018, ...small update. and it's not worth to buying it.
And where are sport people... We design buildings, not construction sites...
With all respect - You have to try better...
twinmotion fail.jpg (63.17 KiB) Viewed 960 times
Rafal
MAKE Arkitekter Oslo
Taros Nova
Re: 2019 brakes texture
Thu 28 Jun 2018 05:43
Same here, textures are distorted ...compared to 2018, big dissapointment.
Martin
Filsparo
Mon 9 Jul 2018 02:04
Mine is worst... Importing my model from archicad... i noticed a lots Broken textures on the walk way and road on the scene i uploaded.
Also if i save, quit and come on the project later it doesn't update my model form Archicad... it just keep closing unexpectedly :cry: :cry:
So i have to make sure i finish everything on archicad first before uploading it on Twinmotion 2019 because it would not update my model if i try working with both at real time .
I will just keep using Twinmotion 2018 v2 until this bug are fixed.
Capture new.JPG (82.39 KiB) Viewed 885 times
Capture 3.JPG (55.7 KiB) Viewed 885 times
Joost Lenders
Fri 13 Jul 2018 06:43
Having the same problem.
It looks like the texture of the materials 'blur' to one point. In TM2018 this wasn't a problem, the material expanded seamlessly. Hopefully this problem can be fixed!
Thanks in advance!
Image 24.png (3.29 MiB) Viewed 860 times
Return to “Feedback”
