starterr
simple bathroom
Thu 14 Nov 2019 18:14
Hello
my aim is to make model of bathrom in archicad 16, and in Artlantis 4 quickly choose and change real shaders downloaded from web page.
model has 3walls with floor only, without roof - all to have quick view inside
problem is that im satisfied with colors only in preview /left cklick and move button/, but when unclicking move buttons or simply creating renders im not happy with the result - drasticly chaange of colors of wall tiles and floor tiles. wood is ok
tried sun settings, shader settings, light setting but its started to be sooo complicated that is complete wasting my nerves and time and its no efficient. i dont need super extra render, i just need quick choose and change shader and see result
thanks in advance for help
cheers
tomas
Byt Hrubala Tomas better 3a tmava dlazba.zip
(183.27 KiB) Downloaded 23 times
Byt Hrubala Tomas better 3a tmava dlazba Tahotny.zip
(91.07 KiB) Downloaded 20 times
Byt Hrubala Tomas better 3a bez dlazba.zip
(72.71 KiB) Downloaded 20 times
Re: simple bathroom
Fri 15 Nov 2019 09:22
Thank you for your input, but we do not support Archicad 16 and Artlantis 4, anymore.
If you need only a quick render I would suggest to use Archicad internal render.
Best regards,
