akmal2990
Muddy Mirror reflectance in Artlantis 2020
Tue 31 Mar 2020 17:22
I'm new in Artlantis 2020 (in mac), when I put in render objects, mirrors reflectance are absent (so muddy), like in photo below. Please can you help. Thanks in advance.
Снимок экрана 2020-03-31 в 22.21.48.png (79.68 KiB) Viewed 1499 times
Re: Muddy Mirror reflectance in Artlantis 2020
Tue 31 Mar 2020 17:58
It is because you use the Denoiser, it blurs transparent shaders.
Unfortunately this issue won't be fixed, in fact it is more a limitation than a bug...
Here is an explanation from Thomas, one of the developer at Abvent in charge of the rendering:
The algorithm doesn't know if the material has a reflected, a transparent or just a diffuse channel.
When the energy/light variation is low on a surface, it blurs the result, whatever we could see behind the glass, or through the mirror.
It is a limitation inherent to the chosen algorithm.
In other words, the algorithm works only on the first shading level.
akmal2990
Tue 31 Mar 2020 19:21
Thank you so much for explaining this issue, but without denoiser I couldn’t reach like this good quality of picture, especially floor tile. The picture was always with noise around. Can you explain how can I reach best result, I mean with no noise, without denoiser?
Thanks in advance!
Wed 1 Apr 2020 10:39
The noise can come from Neon shader, HDRI lighting, Enhanced Background, depending on the origin we can use different rendering settings to reduce it.
I would have to see your rendering settings and shader settings to help you better.
You can send me your atla file, zipped by WeTransfer at sarrut@abvent.fr
Return to “Shaders & Textures”
